So, I have started the process to configure the SDK, and I am seeing some errors.
npm WARN old lockfile FetchError: request to https://registry.npmjs.org/@babel%2fcore failed, reason: self-signed certificate in certificate chain
npm WARN old lockfile at ClientRequest.<anonymous> (D:\Program Files\nodejs\node_modules\npm\node_modules\minipass-fetch\lib\index.js:110:14)
npm WARN old lockfile at ClientRequest.emit (node:events:526:28)
npm WARN old lockfile at TLSSocket.socketErrorListener (node:_http_client:442:9)
npm WARN old lockfile at TLSSocket.emit (node:events:538:35)
npm WARN old lockfile at emitErrorNT (node:internal/streams/destroy:164:8)
npm WARN old lockfile at emitErrorCloseNT (node:internal/streams/destroy:129:3)
npm WARN old lockfile at processTicksAndRejections (node:internal/process/task_queues:83:21)
npm WARN old lockfile Could not fetch metadata for @babel/core@7.15.8 FetchError: request to https://registry.npmjs.org/@babel%2fcore failed, reason: self-signed certificate in certificate chain
npm WARN old lockfile at processTicksAndRejections (node:internal/process/task_queues:83:21) {
npm WARN old lockfile code: 'SELF_SIGNED_CERT_IN_CHAIN',
npm WARN old lockfile errno: 'SELF_SIGNED_CERT_IN_CHAIN',
npm WARN old lockfile type: 'system'
npm WARN old lockfile }
[#######...........] \ idealTree:inflate:@babel/generator: sill inflate node_modules/@babel/generator
So, this makes me think there may be a Firewall issue, however if I run...
npm config set strict-ssl false
I get further, but I still am seeing errors
npm ERR! code ERR_SOCKET_TIMEOUT
npm ERR! network Socket timeout
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
Any Ideas? I am trying this on a Virtual Desktop on vxRails. I see no issues off network on my laptop, so definitely a internal IT issue.
