Is there a way in Experience Builder to exclude specific layers from the exported legend? I have turned off appearing in the legend toggle in MapViewer for certain layers, but when I export using the print widget those layers still appear unless they are turned off. I need these layers to be visible as they are reference layers (roads, municipal boundaries, etc.). I thought toggling in MapViewer to have these not appear in the legend would work but it only excludes them from the actual legend widget that you can use and not the print widget legend when exporting a map.
I also would like to know more about customization options for the print widget and how much I can customize what the final exported layout looks like.
