Hi experts,
I recently started using ArcGIS Experience Builder Developer Edition and developed one application. Now to deploy the application to a web server I need to download. I am unable to download the application and getting the following error ,
[Error: ENOTEMPTY: directory not empty, rmdir 'D:\Programs\ArcGIS\arcgis-experience-builder-1.11\ArcGISExperienceBuilder\server\temp\3\cdn\6\calcite-components\assets\color-picker\t9n'] {
errno: -4051,
code: 'ENOTEMPTY',
syscall: 'rmdir',
path: 'D:\\Programs\\ArcGIS\\arcgis-experience-builder-1.11\\ArcGISExperienceBuilder\\server\\temp\\3\\cdn\\6\\calcite-components\\assets\\color-picker\\t9n'
Kindly assist.
Regards, Qaiser
Did you ever get a solution to this?
Same Issue
Are you able to elaborate anymore on what you mean by permissions?
I'm also having this issue but it's I suspect it is not related to permissions as stated above. When I try and run the "download" I can see the ...\ArcGISExperienceBuilder\server\temp folder becoming active with files been written into it in preparation for the zipping-up. The issue seems to be with the clean-up phase, when it is trying to clear out the folder again.
I would find that every time I run it would have the error vary between codes "ENOTEMPTY" & "ENOENT" and the folder path would be different every time as well as the time it takes to fail.
ExB version: 1.13
Infrastructure: Amazon Web Services EC2
Edit:
I have found a thread that also discusses this issue in depth:
Possible solution if the EXB download fails - Esri Community
Cheers!
