I have set up a print widget so our end users can print their map extent as a paper map with the legend of visible layers/drawn layers, north arrow, scale bar, etc.
Every time I test it in the viewer the export fails. I'm using a feature group map image layer as my basemap with coordinate system WKID 26917 which is the same CRS for all other layers in the map. It still fails every time even if I have all layers off and just try to print the basemap.
I know the web map adopts the CRS of the basemap so that would make me think the map is in 26917 as all the layers that are part of the map image basemap are in the same CRS. I am lost as to why it keeps failing to export since everything is in the same coordinate system.
