How to open a Hyperlink field in ArcGIS Portal or AGOL
292
02-26-2024 05:40 AM
JoseSanchez
Occasional Contributor III
Good morning,
Is there a way to open an Hyperlink field? May be  using  Experience Builder?
All documents related to a project are stored in the corresponding folder:  server/storage folder/project number.
For example, all documents related to project 100 will be stored in  folder: \\server\project\100  then in the FC for project 100 there is a field called DocPath with the value:  file:///\\<server>\<project>\<project number>
This is a hyperlink field, so it can be clicked in ArcGIS Pro and it opens the specific folder. In a WebMap it does not work.
How can I do the same thing in Agis Portal/ AGOL?
Thanks
JakeSkinner
Esri Esteemed Contributor
@JoseSanchez ,
Unfortunately, ArcGIS Online does not support UNC paths as hyperlinks.  See the alternative solutions in the below link:
https://support.esri.com/en-us/knowledge-base/faq-does-arcgis-online-support-unc-paths-as-hyperlinks...
BlakeTerhune
MVP Regular Contributor
It's a browser thing. It seems modern browsers prevent this intentionally for security. You could try some browser extensions to allow it (at your own risk).
JoseSanchez
Hi @JakeSkinner    @BlakeTerhune
Is there a way to call  a geoprocessing Python tool from the Popup Window that will open File Explorer.  Folder passed as  parameter.
import os
path = "\\\\server\\folder\\project"
path = os.path.realpath(path)
os.startfile(path)
BlakeTerhune
Yes, if you are able to host the Python script as a geoprocessing service.
