I built a dirt simple two-page app with ExpB that works perfectly on iPhone+Chrome. Page 1 = Map view, Page 2 = table view. The map contains points along a calculated route, and the user can select a point and switch to the table page where the record is selected and they can edit data about the point. Or they can select a record in the table page, switch to map view, and the map will zoom to and flash the point.
However, on Android (both a Galaxy and Pixel) + Chrome, when a feature is selected on the map, the map goes blank, none of the navigation buttons work. Clicking somewhere on the blank map/space will cause the map to display, but the selection is lost. Selecting a record in the table then switching to the map has the same behavior -- the map is blank. Clicking somewhere in the blank space will cause the map display and it's zoomed in to the record/point that was selected in the table.
Unfortunately, I can't link to the app b/c data security, but can build a non-editable version if need be.
