I am using EXB version 1.12 and am trying to add the Near Me widget to a new application. After adding the widget and selecting the map in the widget settings, I get a message that appears in the widget:
I have no idea what I am supposed to be configuring in the web map because there is no documentation that I can find on what exactly needs to be configured. I do NOT want to do any analysis, just want to find features based on a location (like the WAB version). The map only contains a single point layer hosted at ArcGIS REST services. I looked at the web map settings on the details page and don't see anything that needs to be configured. Can someone please let me know what I am missing? Thank you!
I figured it out, but I will leave this post up in case someone else has the same issue. The message is just misleading. Apparently it is just a generic message letting you know that you haven't configured anything in the Near Me Map Settings. Once I clicked the Add Analysis button and set the analysis type and distance/etc the message was gone.
