In Arcgis Explorer 1500, is there a way to access the event that fires when a user single clicks on a feature on a map resulting in an HTML popup window? We would like to have some custom code run as a result of the same "identify" click event that results in the popup window. For example, in addition to having the HTML popup window appear, we would also like to change the color of the selected feature. Thanks.
