If you can post a snippet of your code I'll take a look. Is this version 1500?
Cheers
Mike
On your dev machine what happens if you check the file exists first e.g. System.IO.File.Exists() or create a new in memory BitMap from the file on disk before using in the CreateMarker method?
Cheers
Mike
