I recently reported an issue to ESRI and thery replied back that it is a bug and gave it the number NIM076987. The bug is in the enumerator of RowCollection, if you run a foreach loop on a rowCollection, then sometimes this loop will break in the middle, or even break at the begining.
I was trying to add the results in the row Collection to my array of objects using a foreach loop, but I bumped into this bug. I then tried to give the TableBindingAdapter as a direct datasource to mu grid or combo box, but also same result. Some times the grid is filled with all the data, other times some of the data, and in rare case no data at all !!!
Anybody has an idea to a workaround for this issue?
Regards
