HELP ME :) ArcGIS Explorer + Vista Home 32Bit
2024
05-04-2012 06:23 AM
MichaelAgnes
Hello:
I have tried several times to install and run ArcGIS Explorer on my laptop and the closest I get is the ESRI Splash Screen and Frame for Explorer and it falls down Dead. Is there a log file that tracks the cause of death ?
Here is my configuration.... Any and all help appreciated.
Mike
1- I have;
Microsoft .NET 3.5 SP1 and .NET 4
JAVA 6 Update 7 and 31
MSXML 4.0 SP2 Parser and SDK
Current Drivers for Video Card
2- I have tried
Current Build and past builds
Online Version works fine
3- I have run the Can you Run it test - Results below
Os is Vista Home Dition 32 Bit
PC is Dell Inpriron
You Have: Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00GHz
PASS
CPU
Recommended: Intel Core Duo, SSE2 (or greater) Pentium 4 or Xeon Processors
PASS
CPU Speed
Recommended: 2.4 GHz
You Have: 2.0 GHz Performance Rated at: 3.30 GHz
PASS
RAM
Recommended: 2 GB
You Have: 3.5 GB
PASS
OS
Recommended: Windows XP minimum SP2, Windows Server 2003 minimum SP1, Windows Vista minimum SP1, Windows Server 2008 or Windows 7
You Have: Microsoft Windows Vista Home Basic Edition Service Pack 2 (build 6002), 32-bit
PASS
Video Card
Recommended: 256 MB video card with Pixel & Vertex Shader 3.0
You Have: Mobile Intel(R) 4 Series Express Chipset Family
PASS
Features: Recommended attributes of your Video Card
Required  You Have
Video RAM  256 MB  1.5 GB
3D  Yes  Yes
  Hardware T&L  Yes  Yes
  Pixel Shader version  3.0  4.0
  Vertex Shader version  3.0  4.0
Free Disk Space
Recommended: 198 MB
You Have: 20.2 GB
PASS
MichaelQuinn1
I have a similar problem with the same platform. The display window within ArcGIS Explorer is transparent to my desktop! Just got off of the phone with tech support. No solution yet (currently waiting for a call back). I suppose there is some comfort in learning that I am not the only one experiencing the display problem on a Vista machine.
GregoryRoss
Did you run the install as an administrator?
