EDIT: I believe this may be a rasterization problem. After converting the shapefiles to raster, I am getting the streaks, and when I sum the raster images, the problem is amplified. I have double checked. and the values are NOT correct over the top right region of the map. The values are corresponding to the "color values" that are actually not correct in that area. Can anyone help me solve this problem? I have this same problem with 3 different data sets.
Regards,
Cyndi
