I am fairly new to arcgis explorer and I am having an issue with my popup for multiple feature selection window.
my main feature is a row_tract file and i have set the display expression in arcmap as a tract attribute. when i create a layer file or layer pkg instead of show the tract attribute as the multiple selection it is showing another attribute called subsys_nm. i have tried many things to try and fix this.
if you look at the imagesone is of the multiple feature selection box and the other is the attribute data box.
basically in looking at the attribute box i want the title sec 12 to be the option that shows up in stead of the subsys_nm
