The questions are:
1- How can I convert this coordination system,
On the Display tab, click the Coordinates combobox and select <..More..>, then select the projection you wish. You can also click the Explorer world button at the top left, click map properties, 2D or 3D coordinateSystem, then choose projected. The positional bar will show you your location based on that projection, in the units of the projection also. When you look at the properties of a note etc, you will see that the lat long values are described in units of your chosen projection.
2- What is the coordination system that I should use,
WGS-84 is the best world wide projection
3- My objective is to have the Units in meters or Kilometers, because I need the ASCII file of the dem for further applications.
Change the Distance combobox to Meters, Kilometers. If you want to perform measurements, simply change the Measure tool's units to kms or meters.
Edan
