Right okay. So with the URL data, when/if the numbers change, the map also changes to display the updated numbers. For example, the weather forecast layers that are available on the ArcGIS Online "Add Content" search change as the weather forecast receives updates on the website.
So if someone takes the URL approach, are they able to add new columns/attributes of data or should that be set up prior to establishing the layer?
