Original User: emmarita
I've got a polygonal shape in Monte Mario Italy 2.
When i add it to my map in Arcgis Explorer Online, the features are in the wrong position (see image attached): the red feature i drew is in the right place, the green feature is from my shapefile.
The prj is defined in the txt attached.
The same error occurs when i use ArcGis Explorer (desktop), but i partially solved changing the 'trasformation' in 'map properties-2D coordinates system'.
It means that in this way i have my shape correctly projected, but when i change the basemap, the errors occurs again.
In ArcGis Explorer Online i don't know how to solve this problem.
All that doesn't occur in ArcMap, every basemap i load, my shapefile in Monte Mario Italy 2 is correctly reprojected.
Thank's for any help.
Emmarita
