Additional MDM variables for ArcGIS Field Maps
777
12-19-2021 09:06 PM
BrettHeenan
New Contributor II
The Australian Department of Defence has requested additional functionality for MDM custom variable fields.
For organisations with a large number of mobile devices used to collect data, standardising the configuration on each device can be a time consuming activity. Adding additional items such as the track settings and cellular data settings to the Field Maps MDM custom variable fields will assist organisations with their device management.
Tags (1)
3 Comments
by Anonymous User
@BrettHeenancould you expand on which track settings you'd like to see available for MDM configuration? The track upload and last known location update frequencies are already available.
BrettHeenan
@Anonymous User
In the Field Maps App the user is able to set "Enable my tracks > Duration until switched off" and in "Settings > Cellular data > Sync and Update (On), Downloads (On)".
The customer would like these options to be included as an extra MDM variable to facilitate easier configuration of ~1000 devices.
Hope this helps.
ahargreaves_FW
@Anonymous User the ability to "reload map(s)" via an MDM push would be much appreciated. If we've made changes to a map, including symbology, popups or FieldMaps forms we need a user to manually hit "reload maps". Many field users are bad at following instructions and so the ability to enforce this, via an MDM push, would be super valuable.
