Arcade Expression (Logic - Required)
334
10
4 weeks ago
AidosMalybayev
I'm new to arcade and trying write a simple expression to put logic requirement in a field.
I have three string fields (field1, field2, field3) with domains values (value1, value2).
If in field1 and field2 a specific values and their combination are chosen, field3 must NOT be required for filling if at least one condition match.
I tried but it does not work. Please advise what's incorrect
DomainName($feature,"Field1")!="Value1"||
DomainName($feature,"Field1")!="Value2"||
DomainName($feature,"Field1")!="Value3"&& DomainName($feature,"Field2")!="Value1"
Tags (3)
KerriRasmussen
If(DomainName($feature, "Lithology") == "Tuff"){
    return false;
  else if(DomainName($feature, "Lithology") == "Silica Rock" && DomainName($feature, "Protolithology") == "Tuff"){
  return false;
  else if(!IsEmpty($feature["Lithology"])){
  return true;
else {
  return false;
KerriRasmussen
Good morning,
One suggestion I have for you is flipping your expression to the positive, meaning you will want to give the case(s) for when the field should show as required, instead of when it's not required. And when you do that you will want to use == when setting the fields equal, for example -
DomainName($feature, "Modify_Date") == "Yes"
 It's much easier to work in the positive with Arcade.
Kerri
RPGIS
Another option that works as well is using contingent values. This will automatically limit values based on inputs of other values.
jcarlson
The phrase "at least one" sounds like the function Any. Put your conditions in an array, then use Any to return a true/false value if anything comes back.
Any([
  DomainName($feature,"Field1") != "Value1",
  DomainName($feature,"Field1") != "Value2",
  DomainName($feature,"Field1") != "Value3" && DomainName($feature,"Field2") != "Value1"
- Josh Carlson
Kendall County GIS
RPGIS
The Includes function or a for loop I believe could also work as well. Plenty of options for achieving similar results.
AidosMalybayev
There is an error:
Test execution error: Execution error - Call with wrong number of parameters. Verify test data.
KerriRasmussen
Good morning. Would you mind sharing your Arcade Expression? It's easier to troubleshoot that way.
AidosMalybayev
Good day,
Apologies for delaying with response.
There are three fields:
  • Lithology (Lith) - domain list with more than 30 values with two specific ones interesting for us - "Silica Rock" and "Tuff"
  • Protolithology (Protolith) - domain list with more than 30 values with specific one interesting for us - "Tuff"
  • Lithology Texture (Lith_text)  - domain list with more than 10 values
Lithology Texture field required when:
  • Lithology not empty
Lithology Texture field NOT required when:
  • Lithology = "Tuff"
  • Lithology = "Silica Rock" AND Protolithology = "Tuff"
My expression:
1 DomainName($feature,"Lith")!=null||
2 DomainName($feature,"Lith")!="Tuff"||
3 DomainName($feature,"Lith")!="Silica rock"&& DomainName($feature,"Protolith")!="Tuff"
It works with first line only.
Two others are not working i.e. Lithology Texture field with asterix (still required)
P.S. Expression
Any([
DomainName($feature,"Lith_1")!=null,
DomainName($feature,"Lith_1")!="Tuff",
DomainName($feature,"Lith_1")!="Silica rock"&&DomainName($feature,"Protolith1")!="Tuff"
return: Test execution error: Execution error - Call with wrong number of parameters. Verify test data.
KerriRasmussen
    return false;
  return false;
  return true;
else {
  return false;
AidosMalybayev
Thanks @KerriRasmussen !
