Does anyone have a solution to generate a new random point from the Field Maps app, similar to the Create Random Points geoprocessing tool in ArcGIS Pro?
Ideally, this could be done by either selecting a map radius or a constraining feature class. It would also need to work offline with an Offline Map Area.
I am not yet familiar with the Field Maps designer-arcpy interface--is that a path forward?
Context: This is for an environmental study where a sample point may not be reachable and the field team needs to quickly generate a new, unbiased sample point while in the field.
