We have an Arcade expression set up on a field on a point layer, which should automatically calculate when a user creates a new point.
In Android v22.1.0 of Field Maps, this worked well and as soon as the user selected the point layer to create a new point for, the point is auto-placed (when accuracy is good enough) and the field is calculated.
In v22.1.1, this doesn't happen. When the point is auto-placed at the user's current GPS location, the field with the Arcade expression doesn't automatically populate, it says "Failed to calculate". The only way you can get it to work is to use the "Update point" button, and then the Arcade expression calculates.
Just wondering if anyone else has experienced this? Is it a known bug with the latest update?
