It's good to know that the survey123 form allows more complex formatting - and I think that might be applicable to my scenario. I designed it in Survey123 Connect with the goal of having quality attribute data, including photo file naming.
I'm not sure I completely understand you - and I think this relates back to my original question about the @esri webinar. Did the survey123 form in the webinar use the existing feature layer and form designed in Field Maps designer?
@DougBrowning wrote:
It would be nice if you could use and Hosted layer in the 123 tools for sure. I think you can get around this by having the form out there tied to a service then just use that service in a Field Maps form also. No real reason you cannot. They are both just dumping data into the same place.
