Tag, label, or name photos in Field Maps?
1274
11-01-2021 03:58 PM
KBKnight
Hi there,
I need to take photos and associate them with polygons using Field Maps. There are often multiple photos associated with a given feature. I would like to have a way to label these photos as "primary, secondary, etc." so that users know which photos are the most valuable for our purposes. Is there a way to tag these photos or rename them as part of the process of acquisition?
LiLin1
by Esri Contributor
I would suggest you to use the rename attachment feature. After you attached an attachment, for example, take a phone with camera app, tap on the photo thumbnail to view the attachment, tap on the overflow menu and choose Rename.
I hope it helps.
Li Lin
