I found a bug where using the "Generate Label" command wipes out the attributes from the field they were generated from if you undo the label creation.
Steps
1. Execute generate label command on a web feature layer.
2. Undo the label creation.
3. The attribute field is then blank.
I am on the most recent release candidate.
