Hi all,
I successfully setup a Power BI desktop project with multiple pages linking to AGOL. Then suddenly on the 18th of March (should the date be meaningful) the existing project started displaying a blank sheet with a notification ' Access to this content requires permission. Sing in below, or contact the content's owner for access. Learn more. Connect to ArcGIS' - clicking on the 'Connect to ArcGIS' does not bring up the login prompt (nor does it cause any other action).
If I start a new page within the project and try to access ArcGIS Maps for Power BI I'm prompted to sign in to ArcGIS Online, however the 'Sign in' button does not bring in the login fields either. You can only add Excel data, which will show up against an Esri basemap - that's all.
Starting a new Power BI project has the exact same issue - only excel data can be shown with an Esri basemap - the connect to buttons do NOT bring up login fields.
I've emptied the 3 different caches in the Power BI Options (Data, Q&A and Folded Artifacts) - but this has no effect on the situation.
I've attached a diagnostic file from Power BI desktop.
Any help would be greatly appreciated!
