I'm trying to use the ArcGIS Web Map part to pull up the links for the documents I have geocoded in a Sharepoint library. All the documents have an X and Y column that are referenced by an Esri Location column. I created a site page and configured the attribute table to return the document's Name and Type fields (which actually pulls the LinkFilename and DocIcon fields). I know it's accessing the server because it returns the Modified field values and FileLeafRef name (same as LinnkFilename w/o the link). It just doesn't return the document links or icons. Any ideas? Is this a Silverlight security issue?
Bryan
