Maps for Office Fails to Load in Powerpoint
3388
11-13-2012 05:11 AM
ShaenSomerlot
I have installed maps for Office v1.1 (32 bit version) on a windows 7 64 bit machine.  We have Office 2010 (32bit Version) installed on the same machine.
Everything works fine in Excel but I can not get Maps for Office to load in powerpoint.  The ribbon menu does not load.  I have tried to manually add it and I get this error.
[ATTACH=CONFIG]19253[/ATTACH]
Any thoughts on why this is happening in Power Point but not in Excel.
Robert_LeClair
Esri Notable Contributor
Shaen,
Try this:
1.  Launch the PowerPoint application.
2.  Go to File > Options> Add-ins.
3.  Go to Manage > select COM Add-in.
4.  The ESRI maps for Office > Go. Check on the add-in for ESRI .
5.  In the Manage option > Disabled Items > Go. Enable the ESRI add-in add-in.
Does the ribbon now appear in PowerPoint?  Please advise.
Regards,
Robert LeClair
Esri-Denver
ShaenSomerlot
I went through your suggestions but that wasn't it.
I do not and have never had the ESRI application in the Disabled Application Add in list.
[ATTACH=CONFIG]19256[/ATTACH]
Robert_LeClair
Hmmmm, I would recommend you contact Esri Support Services at your earliest convenience.  They'll be able to view your screen and troubleshoot the cause of this error.
