Static Range on Thematic Map
1394
05-02-2014 11:23 AM
PhillipIrwin
I have a report that I built that has a U.S. State thematic map, and the data behind it changes based on parameter values that are provided by the user. The data values that result could be widely different than the values that Map Designer sees when configuring the map causing the thematic to apply the "other" formatting, which can cause all states to render as one color.  I was wondering if there is any way to allow number ranges to be dynamic.
Thanks in Advance!
Tags (3)
