I am using ArcGIS for Windows mobile. I can successfully create a mobile cache if the service is not secured. However if I add security or try to use a token it fails on the CreateCache with a nullReferenceException. Any ideas are appreciated!
//@"http://<YourServer>/<YourArcGISServerInstance>/rest/services/<YourMobileServiceName>/MapServer/MobileServer";
MobileServiceConnection mobileServiceConnection = new MobileServiceConnection();
mobileServiceConnection.Url = mobileServiceUrl;
//if the line below is commented out this works flawlessly. If I add this line on the CreateCache line below it will fail
mobileServiceConnection.TokenCredential = new ESRI.ArcGIS.Mobile.CatalogServices.TokenCredential("MyUserName", "MyPassWord");
//these next 2 lines are just an alternate that I tried
//mobileServiceConnection.TokenCredential.UserName = "MyUserName";
// mobileServiceConnection.TokenCredential.Password = "MyPassWord";
mobileCache1 = new MobileCache(cacheStoragePath);
if (mobileCache1.CacheExists == true)
mobileCache1.DeleteCache();
if (mobileServiceConnection.IsValid)
MobileCacheTextBox.Text = "isValid";
else
MobileCacheTextBox.Text = "Not Valid";
//the line below is where it returns a nullReferenceException when the Token is being set
mobileServiceConnection.CreateCache(mobileCache1);
mobileCache1.Open();
return true;
