Pieter,
Can you be more specific regarding your workflow and number of attachments? Have you contacted Esri Support or if you are outside the US, your local International Distributor?
Thank you,
Denise
I have contacted our local distributor and they have logged a call with the Esri International, but it is taking a very long time.
My workflow is pretty straight forward, I share an mxd containing sde feature classes to argis server, and perform all the necessary steps to allow for mobile collection (globalid, version the db, add attachments and also allow for attachments in the mobile project centre).
I then proceed to collect and edit several features and one or two photo attachments for each feature.
I synchronize the updates to arcgis server successfully (no error messages)
Then I proceed to check the updates in arcmap, and notice that all the attributes have been synchronizes successfully, but not the attachments.
Weirdest thing is, that only in some cases the attachments does get posted to the server.
If I can understand the variables in the process when the updates get posted, I may be able to narrow down on the problem.
Have you any advice for me?
Much appreciated
Pieter,
Who is your local & International Distributor?
What type of data is your service based on - MXD, View, Table?
Have you tried working with the Feature Service Web Editing Tutorial?
Tutorial: Feature service web editing
http://resources.arcgis.com/en/help/...000005mm000000
sample data & workflow supports enterprise GDB, feature services & web editing data workflows
Denise
Whilst capturing features on my operational layers, the attachments does not get synchronized back to the server. Even though all the other attributes are sent to the server successfully, in some cases the attachments are left behind. I'm not getting any error message during synchronization.
Did anyone have this problem before?
Hi Pieter,
We (my workplace) are currently experiencing the exact same problem you have mentioned here. We were wondering if you ever received a resolution to this issue of attachments not uploading or whether you decided to try another methodology.
Regards,
Rosalie Buck.
