Missing the Mobile Tools Toolbox in 10.2
6725
13
08-01-2013 09:24 AM
DouglasBraeckel
Does anyone know if the Mobile 10.1.1 toolbox shows up in Desktop 10.2 or do I need to use Desktop 10.1?  It doesn't even appear to try to install the .tbx from what I can tell.
Doug
RobertRayner1
It may not show up automatically, have you tried adding it from Toolboxes>System Toolboxes>Mobile Tools.tbx?
AdamMcClure
Thanks, RobertRayner - I'm running 10.2.2 and just found this toolbox as it was not installed initially. Your solution nailed it.
WilliamSands
OK I think I have worked it out. My ArcGIS for Windows Mobile 10.2 installer had the Geoprocessing Tools turned off by default. I have since re-run the installer and have installed the Mobile tools successfully.
DarrylSanchez
When you were having problems with the installation of the Geoprocessing Tools did you see three or four drives when you first install mobile?
