Sync a mobile Cache
2667
10-02-2014 12:13 PM
RobbSchuldt
Hello, I am working with ArcMobile 10.2 and ArcMap 10.2  I have built a file geodatabase with a feature class, created mobile projects (Using Create Mobile Cache tool), deployed to mobile devices which use ArcMobile 10.2.  The mobile devices do not have internet access and are using disconnected editing.  Initially things worked great, I would copy the cache from the unit to my PC, use the Synchronize Mobile Cache tool and check in data.  However recently, I was trying to check in a rather larger amount of data than usual, the tool did not synchronize the data properly, points appeared in ArcMap, but no actual data.  (Attribute table was empty).  I could not edit the points as an error kept appearing that the there was a loss of data.  Eventually I deleted the feature class and copied data from a parent feature class.  Now, I cannot synchronize data.  Any suggestions on how to get the data (mobile cache) off the unit and back into a file geodatabase?
Many thanks in advance,
~Robb
