Transparency or Opacity property is not available on Map Graphic Layer
1800
03-31-2017 12:27 AM
Udaya_BhaskerCheerala
Hi All,
I am adding custom graphic layer to map, I am building custom graphic layer by inheriting the map graphic layer. I would like to set the transparence or opacity property of the custom graphic layer, but this property is not available map graphic layer hence also not available in custom graphic layer as it is inheriting form map graphic layer.
Is there any work around to set transparency or opacity property of custom graphic layer?
Uday
