Would it be possible to add Geotab's Gear position field to ESRI's Geotab connector, found here? We're working on a web map that shows when one of our trucks is servicing a given hydrant in the field, but are encountering false positives when the vehicle is waiting at a red light near one of the hydrants, for example. If we could filter against the vehicle's gear status, adding a condition to only show those in Park, it'd go a long way towards weeding out the false positives. Geotab's native reporting does show that the gear position values are being captured, but they aren't conveyed to GeoEvent Server via the aforementioned connector.
I just want to echo some support for this idea - we would like to utilize it for a very similar use case.
