It would be highly beneficial to include the specific service from which the error originates. This will facilitate expedited investigation of the issue
+1 kudo
This is one of the main reasons we try to prevent using GeoEvent and only use it when absolutely neccessary. It is nearly impossible to solve errors without knowing its origin.
Unfortunately, Esri is well-known for the weaknesses in its error logging across all products.
