ArcGeo Event Processor as a Callback URL??
3025
03-25-2015 09:51 AM
BrianLocke
Occasional Contributor II
Looking into how to setup AGP as a Calback URL for Spot Devices, would be over HTTPS, I am curious if this is possible and if anyone has done it?  What do you think Ryan Elliott​??
RyanElliott
It sounds like you want to use one of the connectors in GeoEvent that has a name like "Receive XXXX on a REST Endpoint".  There's several of those that can parse different data formats (Features, JSON, etc.)  The connection properties allow you to specify the last part of the url where the GeoEvent process will listen for data from a client.  By default, it listens on port 6180 for un-encrypted (http) traffic, and port 6143 for encrypted (https) traffic.  Ming Zhao​ might have additional input on this.
BrianLocke
Thanks again Ryan for the speedy response I will see what I can do and if I am successful I will post my results, thanks again.
See also:
