I have two point feature classes. FeatureClass1 is updated via a Survey123 project. Whenever a new entry is created, I want to buffer that point and use that as a GeoFence in GeoEvent. That way when FeatureClass2 has an entry, it will check to see if it is in the polygon buffer of FeatureClass1 and send an email if so.
Any help on how to this with GeoFences in GeoEvent would be greatly appreciated! Thanks!
Hi Nicholas Gray,
i haven't worked a lot with geofences so far. But me first idea would be:
Hope this is helpful,
Best Stefan
Thank you Stefan! I'll give that workflow a shot. Based on what I've looked at so far, that should work.
You don't have to use a geotagger and than an attribute filter, you can directly use a spatial filter.
Best, Stefan
