com.esri.ges.fabric.internal.ZKPersistenceUtility ConnectionLoss
697
03-24-2017 10:43 AM
JinQian1
I keep getting the following errors from the log file.  I updated the Default ArcGIS Server from the datastore but it didn't cgange anything.
KeeperErrorCode = ConnectionLoss for /geoevent/config/clusters/default/keys/ageskey.jks org.apache.zookeeper.KeeperException$ConnectionLossException: KeeperErrorCode = ConnectionLoss for /geoevent/config/clusters/default/keys/ageskey.jks at org.apache.zookeeper.KeeperException.create(KeeperException.java:99)[23:org.apache.zookeeper.zookeeper-geoevent:3.5.0] at org.apache.zookeeper.KeeperException.create(KeeperException.java:51)[23:org.apache.zookeeper.zookeeper-geoevent:3.5.0] at org.apache.zookeeper.ZooKeeper.exists(ZooKeeper.java:1501)[23:org.apache.zookeeper.zookeeper-geoevent:3.5.0] at org.apache.curator.framework.imps.ExistsBuilderImpl$3.call(ExistsBuilderImpl.java:226)[380:curator-framework:3.1.0] at org.apache.curator.framework.imps.ExistsBuilderImpl$3.call(ExistsBuilderImpl.java:215)[380:curator-framework:3.1.0] at org.apache.curator.connection.StandardConnectionHandlingPolicy.callWithRetry(StandardConnectionHandlingPolicy.java:67)[381:curator-client:3.1.0] at org.apache.curator.RetryLoop.callWithRetry(RetryLoop.java:99)[381:curator-client:3.1.0] at org.apache.curator.framework.imps.ExistsBuilderImpl.pathInForegroundStandard(ExistsBuilderImpl.java:212)[380:curator-framework:3.1.0] at org.apache.curator.framework.imps.ExistsBuilderImpl.pathInForeground(ExistsBuilderImpl.java:205)[380:curator-framework:3.1.0] at org.apache.curator.framework.imps.ExistsBuilderImpl.forPath(ExistsBuilderImpl.java:168)[380:curator-framework:3.1.0] at org.apache.curator.framework.imps.ExistsBuilderImpl.forPath(ExistsBuilderImpl.java:39)[380:curator-framework:3.1.0] at com.esri.ges.fabric.internal.ZKPersistenceUtility.exists(ZKPersistenceUtility.java:300)[71:com.esri.ges.persistence.zookeeper.zk-persistenceutility:10.5.0] at Proxye28244eb_d2a7_4a88_86b5_94df463b8df6.exists(Unknown Source)[:] at Proxyc5a505ea_0ff1_49dc_a092_3e501c79b675.exists(Unknown Source)[:] at com.esri.ges.security.cryptography.internal.GeoEventServerCryptoImpl.doDecrypt(GeoEventServerCryptoImpl.java:128)[100:com.esri.ges.framework.security:10.5.0] at com.esri.ges.security.cryptography.internal.GeoEventServerCryptoImpl.decrypt(GeoEventServerCryptoImpl.java:76)[100:com.esri.ges.framework.security:10.5.0] at Proxyde0b4265_cf64_4d16_ba25_f4f6e9f39b56.decrypt(Unknown Source)[:] at Proxyf81cf484_813a_407d_af29_e61ae2d2f000.decrypt(Unknown Source)[:] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection.decryptToken(DefaultArcGISServerConnection.java:4766)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection.getDecryptedToken(DefaultArcGISServerConnection.java:4789)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection.getDecryptedToken(DefaultArcGISServerConnection.java:4780)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection.getDefaultParamsForRequestAsKeyValueList(DefaultArcGISServerConnection.java:561)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection.updateManagedDatabases(DefaultArcGISServerConnection.java:832)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection.updateCache(DefaultArcGISServerConnection.java:2907)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection$CacheUpdater.update(DefaultArcGISServerConnection.java:166)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0] at com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection$CacheUpdater.run(DefaultArcGISServerConnection.java:206)[104:com.esri.ges.framework.datastore.agsconnection-datastore:10.5.0]
