I'm attempting to read in a generic JSON array containing AVL data via UDP Socket. The array is basically as follows:
{"id":7219,"p":4388,"d":"06802","u":102,"r":"F-E31","s":"R-I","x":0,"c":"","t":"2019-03-15T10:06:50","rack":0,"l":35.918,"g":-79.03748,"z":137,"h":81,"m":14,"a":5}
I continue to get an "Event Not Matched" warning followed by a "Failed to parse the incoming JSON" error for every incoming record. It seems like the GeoEvent definition file is correct, but I must be missing something. I've attached screenshots of the input connector configuration, the GeoEvent definition, and the error log. Any suggestions?
Chase
