I just upgraded from 10.3 to 10.4.1 for ArcGIS Server and GeoEvent. I also updated to the 10.4 versions of the Trimble and Networkfleet adapters. However, I am getting errors on my inputs saying that the adapter is not available for both of these. Do I need to downgrade to 10.4 or should the 10.4 adapters work with GeoEvent 10.4.1?
Seeing the same for the Twitter Adapter as well.
Solved! Go to Solution.
Had to recreate the connectors after adding the latest versions of the adapters.
