GeoEvent 11.1
Am trying to output features from geoevent to a featureservice, and have noticed, that only 1 instances is ever used on the server. is there a way to increase this?
Geoevent seems to process my events quickly, but writing to the DB is slow, so although i can process 52k records quickly in geoevent (in and out within seconds) the count in the DB takes about 4 minutes until all records reach there.
The feature service only ever has 1 instance being used for that 4 minute duration.
Any help?
Steve
Solved! Go to Solution.
The GeoEvent output is going to act as a single client making requests to the feature service to add or update feature records. A single client, does not use a feature service's pooling configuration as a scaling mechanism.
Pooling is available so that the feature service can manage requests from multiple clients making concurrent requests.
Additional References:
