How to use a field value from an event definition to set the query parameter in an output connector?
673
09-20-2019 11:49 AM
SatwikMishra
Am fetching token from a place, and want to push JSON to a <base url>?query=token. The token is a field value in a GeoEvent definition. Is there a way to point the parameter attribute of the connector to the field value while setting the output connector?? (Tokens is the event definition for the input connector that fetches the token)
Stefan_Jung
Hi Satwik Mishra‌,
I don't think this is possible with the out of the box connector.
For what i know Parameter is just a simple static string value. The HTTP Outbound Transport adds this value to the URL.
If there is no hidden magic somewhere, you need a custom output connector.
Best Stefan
SatwikMishra
Hi Stefan P. Jung‌ it'd be great if you could throw some light!
Stefan_Jung
Hi Satwik Mishra‌,
Best Stefan
