Hello Ben -
Unfortunately the capability I think you are looking for was built into the 10.3.1 release. It might be available at the 10.3.0 release ... but is not available in the 10.2.2 product.
Similar to K's post Re: Anyone have any luck with passing a user name and password the the Poll an External Website for... (which I saw you marked as helpful) ... in which she's configuring a parameter 'Parameters' exposed by the input ... the 10.3.1 release exposes a new 'Header Parameter Name:Value List' parameter you can configure with a comma separated list of Name:Value pairs you want GeoEvent to send with each of its requests.
Keep in mind that because just about everything that GeoEvent does is RESTful there is nothing that prevents an ArcGIS Server / GeoEvent 10.3.1 instance from polling an older ArcGIS 10.2.2 Server and/or geodatabase ... or using GeoEvent to update features exposed through services published on a 10.2.2 ArcGIS Server.
Sometimes upgrading a production system from 10.2.2 to 10.3.1 is not an option. However, you can stand-up a second ArcGIS Server site (running 10.3.1) which has the latest GeoEvent Extension installed. The obvious downside here is that a second ArcGIS Server site requires a second license; but if you have an ELA that might be an option for you.
- RJ
