We are happy to announce that Empirical Bayesian Kriging (EBK) has been fully peer-reviewed, and the methodology has been accepted into August edition of the Spatial Statistics journal.
https://www.sciencedirect.com/science/article/pii/S2211675319300168
This is the reference you should cite if you need to academically cite Empirical Bayesian Kriging, EBK Regression Prediction, or Empirical Bayesian Kriging 3D in your work or studies.
The article contains an overview of the methodology behind EBK, as well as many results from controlled simulations. The results are very impressive, and they show that EBK performs as well (and often better) than other modern interpolation routines in a variety of situations. It also contains recommendations for when the default parameters are sufficient and when more advanced parameters should be considered.
