Hello,
I apologize if these are too simple of questions, but I had two questions regarding semivariograms:
1) When setting up Kriging with the Geostatistical Wizard, a semivariogram is drawn. Is it possible to create this graph without setting up a Kriging run (I just want the graph, not the Kriging layer). "Semivariogram/Covariance Cloud" does not appear to be the same thing.
2) Can you extract the XY data from this semivariogram (into a tabular format)? You can "right click -> copy" the graph, but that simply saves the image and not the data.
Thank you.
