@Elijah
Each horizontal line of points in the graph appears to have the same Measured value on the y-axis (or very close to equal). However, they each have a different Predicted value on the x-axis.
Having many repeated values in the field you used to interpolate would produce this kind of graph. This isn't necessarily a problem, but you should look into it and confirm that the repeated values are expected in your data.
