My organization has created a template for hazard mitigation planning to be used on a county scale, meaning that we plan to use the template many times. The nature of the work requires frequent changes, which might range from changing text based on government feedback to updates required for the plan to be adopted by FEMA.
To make changes now, we need to first create a new Hub from the template we've created, make those changes, and then save again as a template. Our template has many moving parts, including multiple surveys, dashboards, and infographics, so each time we need to make a change, quite a lot of content is generated by the process. Is there any way to make the initiative templates we've created editable without going through this process?
Hi @JaneLindelof ,
Thanks for reaching out - it's great to hear about your hazard mitigation work. Just to make sure I'm understanding correctly, are you suggesting a way to update a template after it has been deployed and have those update carry down to the sites that have been created with it?
