Dataset showing up twice
1176
16
10-23-2017 08:11 PM
MalcolmJ
Occasional Contributor II
Hi
I'm setting up our version 2 Open Data site and I'm having an issue where a dataset is showing up twice in the datasets list.
https://newversion-marlborough.opendata.arcgis.com/datasets?q=total%20control&sort=name
Both results point at the same ArcGIS Online item https://www.arcgis.com/home/item.html?id=a56ff59d1f8645e188b052f0e96e3789
I've tried unsharing and resharing it again, and reindexing. What else could I try?
Thanks
Malcolm
BPriyaK
New Contributor III
I too am experiencing the same issue with our organizations open data site.
Just as Malcom mentioned ,I have tried resharing it refreshing the index ..but no luck !!
CourtneyClaessens
Occasional Contributor III
Hi Bhanu,
Can you please provide the URLs of the duplicate datasets, if you still see them on your site?
Thanks -
 Courtney
BPriyaK
New Contributor III
Hello Courtney, thanks for your reply !!
Here is the link for the datasets
http://data-airdrie.opendata.arcgis.com/datasets?t=Imagery
The datasets are a document link to the dropbox  to download the files.
The dataset for year 2015 is appearing twice ,where the second one with no thumbnail does not exist.
Any insight will be very much appreciated.
Thanks
CourtneyClaessens
Hi Bhanu,
We'll remove the extra dataset.
Courtney
BPriyaK
New Contributor III
Thank you  Courtney
appreciate it !!
BPriyaK
New Contributor III
Thank Courtney,
I see that the extra dataset is gone !!
Appreciate your help
NinaRihn
I have had that happen before and I was flummoxed and tried all of things you did (sharing/unsharing/re-indexing), and I went home (end of day) and came back the next morning and the extra instance of the dataset was gone.  I think there was probably just a lag somewhere a behind the scenes process and all I had to do was wait it out.
