Error: System resources exceeded
467
04-07-2020 08:29 PM
AmyNguyen
New Contributor II
Just lost about 5 hours of an edit# session for the 2nd time. I'm doing emergency response work for Covid-19 in Texas. Using ArcGIS 10.7. I'm digitizing a zone that covers about 30 counties from mid state to the eastern Red River border. Rivers on the eastern and western edges of the polygon so lots of drawing. I've gotten this "#System Resources Exceeded" error twice now. On 2 different polygons. Machine is not the issue. Losing 4-5 hours of work each time. I don't have time to keep redrawing this. It's not as simple as doing a polygon dissolve, we need a new shapefile- thus the digitzing. It's not a computer/reources issue. I have a 8 month old Dell laptop with an Intel Core CPU @ 2.4GHz with 32GB memory. 64bit OS so it's certainly not disc space. Any suggestions? I'll open a support ticket in the morning if I don't hear back. TIA
MichelleBrake
New Contributor III
Have you tried using a file geodatabase and feature class instead of a shapefile? I wouldn't think the size limitation of 2GB that shapefiles have would be an issue but it may play a part depending on how complex the feature it. When doing a quick google search it seems somebody else had a similar issue, in terms of a large number of edits taking place, that was fixed by using a fgdb instead of shapefile.
-Michelle
geojobe.com
