Additionally, if you don't mind using a bit of CSS, you can change your category link color via embedded <style></style> tags that you can add to any text card in your homepage layout. This would allow you to specifically target the category link color, while maintaining your theme link color for all other links. The text card containing the CSS does not have to be in the same row as the category icons. You can append the CSS to any text card you might already have added to your homepage. Your CSS would look like this:
<style>
.category-panel a,
.category-panel a:hover,
.category-panel a:focus {
color: #003580;
</style>
If you want the category icon to be a different color than the link, you'd still want to set that per icon using the color picker on the Category Settings, which is what I did in the image below. I set the icon to green, and then used my CSS to change the link to blue.
-Klara
