I have an image service I've successfully cached previously. It had four empty scales 1:50, 1:100, 1:250, and 1:500 I created in order that the Geocortex viewer would permit zooming closer than the cached levels.
I have found need to populate the cache at 1:500, and was able to get perhaps a third of the service extent to do so. The table below shows the Cache Status where it is stuck, despite that Level 17 is currently underway for the dozenth or so attempt.
Level | Scale | Size | Expected Tiles | Completed Tiles | Percent | In Progress |
0 | 1,000,000 | 0.18 MB | 6 | 6 | 100 | | 1 | 500,000 | 0.61 MB | 18 | 18 | 100 | | 2 | 250,000 | 2 MB | 55 | 55 | 100 | | 3 | 125,000 | 4.36 MB | 210 | 180 | 85.71 | | 4 | 100,000 | 6.76 MB | 312 | 275 | 88.14 | | 5 | 64,000 | 9.87 MB | 760 | 624 | 82.11 | | 6 | 50,000 | 13.92 MB | 1,200 | 960 | 80 | | 7 | 32,000 | 27.75 MB | 2,886 | 2,356 | 81.64 | | 8 | 25,000 | 39.45 MB | 4,653 | 3,744 | 80.46 | | 9 | 16,000 | 65.76 MB | 11,242 | 9,150 | 81.39 | | 10 | 10,000 | 162.53 MB | 28,405 | 23,183 | 81.62 | | 11 | 8,000 | 228.27 MB | 44,352 | 36,058 | 81.3 | | 12 | 5,000 | 471.78 MB | 113,390 | 91,868 | 81.02 | | 13 | 4,000 | 742.54 MB | 177,408 | 143,395 | 80.83 | | 14 | 2,500 | 1.91 GB | 453,560 | 366,520 | 80.81 | | 15 | 2,000 | 2.79 GB | 708,400 | 572,390 | 80.8 | | 16 | 1,000 | 11.01 GB | 2,832,450 | 2,285,258 | 80.68 | | 17 | 500 | 4.47 GB | 11,327,500 | 2,583,061 | 22.8 | | 18 | 250 | 0 MB | 45,310,000 | 0 | 0 | | 19 | 100 | 0 MB | 283,126,752 | 0 | 0 | | 20 | 50 | 0 MB | 1,132,434,765 | 0 | 0 |
The trouble is the tile count never changes, despite my running Manage Map Server Cache Tiles with each attempt using an Update Extent shapefile covering a progressively smaller fraction of the area needed. So after three hours on an extent of just 30 sq. miles, the job details URL reports 0% completion on each line, with a different Estimated Time Remaining that grows larger and larger before dropping back to begin growing larger again.
The Logs in AGS Manager report what I suspect may be the reason for no tile creation:
SEVERE | Aug 15, 2016, 1:21:23 PM | Error exporting image Wait time of the request to the service 'public/swoop2015_mosaic.ImageServer' has expired. | Rest |
SEVERE | Aug 15, 2016, 1:21:23 PM | Unable to process request. No instances for 'public/swoop2015_mosaic.ImageServer' were available for 60.006 seconds. Wait timeout exceeded. | public/swoop2015_mosaic.ImageServer |
SEVERE | Aug 15, 2016, 1:20:41 PM | Error exporting image Error handling service request :Processing request took longer than the usage timeout for service 'public/swoop2015_mosaic.ImageServer'. | Rest |
SEVERE | Aug 15, 2016, 1:20:38 PM | Processing request took longer than the usage timeout for service 'public/swoop2015_mosaic.ImageServer'. Server request timed out. Check that the usage timeout is appropriately configured for such requests. | public/swoop2015_mosaic.ImageServer |
I don't know what to try next. I have already restarted the image service with no change in behaviour.
Short of contacting Esri tech support, what should I try to correct this issue?
Justin
